The ice chute flapper is making noise when it opens and closes. How do you take off the front cover? I removed the screw but there is a tab or something holding the front cover on how do I get this off?
Groups: Expert
Use a small flat blade screwdriver in the opening in the bottom right corner of the dispenser and pry the right side of the display assembly out. Then pull the display assembly to the right and out.
Thanks it worked great. There was some sticky stuff on the plastic white piece. Cleaned it and now it is quiet.
Groups: Expert
