Grandmm
#1 Posted : Sunday, January 16, 2011 11:55:55 AM(UTC)
Grandmm
I need to remove the oven door to clean the glass inside the door. How do I do that?
Joe / APP Team
#2 Posted : Monday, January 17, 2011 11:58:02 AM(UTC)
Joe / APP Team
Grandmm,
I've attached the door removal and glass removal procedure from the service manual, for you.
1. Open the upper oven door.
2. Raise the two door hinge tabs to the “unlocked”
position.
3. Close the oven door to within several inches,
lift and pull out on the hinges, and remove
them from the oven slots.
4. Place the oven door front side down on a
padded surface to protect the finish.
5. Remove the two screws from each of the
bottom corner glass holders and remove
the holders.
6. To remove the inner oven door glass
panels,
lift each of the three glass panels,
and remove them from the door.
7. To remove the door handle and outer
oven door glass:
a) Remove the three inner glass panels
(see step 6).
b) Remove the three screws from the air
vent and remove the vent.
c) Remove the four door handle bracket
screws and remove the brackets and
handle from the door.
d) Slide the bottom edge of the outer oven
door glass out of the door frame and
remove the glass.
Good Luck,
Coolintx
#3 Posted : Sunday, February 10, 2013 10:26:55 AM(UTC)
Coolintx
You have been a member since:: 2/10/2013(UTC)
MUCH easier said than done! Husband can't even get the hinges all the way out. Have to pay repair person just so I can clean inside of front glass panel. Frustrating! :(
Joe / APP Team
#4 Posted : Monday, February 11, 2013 5:06:32 AM(UTC)
Joe / APP Team
Coolintx, It can be a bit tricky, especially if there's something damaged in the hinge assembly. You also need to keep the door assembly even and level, as you remove it from the oven or the assembly will have a tendency to "hang up" which can get frustrating.
Good Luck and Thanks,
Kitchen Aid oven door removal - going crazy (Oven Repair (including Ranges and Cooktops))
by sun4jessi 10/19/2011 3:08:54 PM(UTC)
