D3RDEYE
#1 Posted : 12 years ago
D3RDEYE
I am a new member here and have a Whirlpool dryer that spins but generates no heat. The timer works if placed in the "Air Fluff" position, but otherwise it does not move in any other "heat" setting. I have read some of the messages here and see that this might be a fixable problem.
However, to be exactly sure, could someone direct me to the specific dis-assembly and testing thread for this particular model # or, otherwise kindly direct me on how to go about diagnosing the specific malfunctioning part on this unit? Any assistance will be greatly appreciated. Thank you.
Simon / APP Team
#2 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Hi.
First you need to check the timer Part number: 3976580
Use the video clip for the instructions.
Remove one black wire from the timer motor contact and check the resistance. If you read no continuity - then replace the timer.
If not - set the timer to AUTO-REG and check continuity between TM-WB, BK-BU, BK-R, T-W. If any of them are open - replace the timer.
You also should check hi-limit, operating thermostat and thermal fuse for continuity. All of them are at the back of the dryer.
Fuse Part number: 3392519
D3RDEYE
#3 Posted : 12 years ago
D3RDEYE
Hello Simon, thanks for your response to my post, have been under the weather over here the last couple of days. You directed that I "use the video clip for the instructions", but I do not see any video clip or link to one. Please clarify.
Simon / APP Team
#4 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Hi.
Click on the fuse picture and you will open another page with video.
Simon.
D3RDEYE
#5 Posted : 11 years ago
D3RDEYE
Simon,
Thank you so much for your assistance. My dryer is once again putting out heat! The instructions and videos were right on the money.
No heat from dryer (Dryer Repair)
by Cvfd626 11 years ago
no heat from dryer (Dryer Repair)
by Robgw007 15 years ago
by bjmyers70 15 years ago
by TimN 15 years ago
no heat from dryer unit (Dryer Repair)
by stefanos 16 years ago
No Heat from Dryer! (Dryer Repair)
by Voyager15 17 years ago
