Let me start out in saying that I have replaced the main circuit board 3 times in the past 2 years.
The ice/water dispenser operates intermittently. It may be fine for a few weeks then nothing. Sometimes i can temporarily solve it by taking out the ice bin and reinstalling it.
Is there a connection where a poorly seated bin will cause this problem? Any other ideas?
Thank you!
I checked wireharness and thad a corroded pin. I was not sucessful cleaning it. It tried to find the harness p/n but I coud not find it. Can anyone help identify the part number?
Thank you for all replies.
Unfortunately it looks like that harness comes as a part of the freezer door only.
Gene, Thank You!
I ended up removing the connector and soldering the wires together. Not the "correct" way but it is permanent.
It's good as long as it's working.
