2 Pages<12
DIYguy13
#11 Posted : Friday, February 8, 2013 2:24:11 PM(UTC)
DIYguy13
If u can force the defrost only by manually advancing the timer then it sounds like the timer is faulty
richardnml
#12 Posted : Friday, February 8, 2013 4:00:32 PM(UTC)
richardnml
I do not believe there is a timer on the model lecr23efe0. in order to manually start the defrost cycle you use the temerature arrowes on the electronic control
#13 Posted : Saturday, February 9, 2013 12:48:37 AM(UTC)
Finally got lucky.
Below is a link to a manual for units that are similar to yours.
I am not sure if they are 100% the same but it is the best I can do.
The file is too large to upload here so I had to use a third party suite.
Uncheck "Use our download manager: and then use the gray "DOWNLOAD" button. Otherwise the sute may install software on your computer that you do not want.
Download Frigidair Icon Fridge.pdf
richardnml
#14 Posted : Saturday, February 9, 2013 10:11:40 AM(UTC)
richardnml
Thanks Denman I appreciate your efforts and persistence!
Originally Posted by: denman Go to Quoted Post
Finally got lucky.
richardnml
#15 Posted : Saturday, February 9, 2013 10:59:38 AM(UTC)
richardnml
how to release two tabs on one side of the control board and a plastic lip that that secure the LCD indicators onthe other side of the control box in order to liift the control board out of the control housing. The instructions on page 42 of the manual do not explain this procedure well.
Do you have any ideas, I do not want to damage the control housing
#16 Posted : Saturday, February 9, 2013 4:49:28 PM(UTC)
Sorry but I do not know.
Also not sure why you are pulling this board.
From what I can see in the wiring diagram this is just a user interface.
Guest (5)
2 Pages<12
