SandraK
#1 Posted : Wednesday, February 6, 2013 8:41:44 PM(UTC)
SandraK
We have a Kenmore side-by-side, model 363.59527996. Four months or so ago the water slowed down and then stopped dispensing through the door. We didn't want to spend any money so just put a pitcher of water in the fridge. This week we noticed no ice in the ice maker. The ice maker is dry. Now ready to get it fixed. I replaced the valve assembly, part number, WR57X10026. Now the water is flowing through the door great, but still no water in the ice maker. I ran the power over from the door water to the ice maker and the ice maker filled up with water. Can you tell me what I need to do in order to fix this problem?:confused:
#2 Posted : Thursday, February 7, 2013 3:09:09 PM(UTC)
Originally Posted by: SandraK Go to Quoted Post
...I ran the power over from the door water to the ice maker and the ice maker filled up with water...
Hello Sandra,
Can you explain more detailed how did you do it please?
SandraK
#3 Posted : Thursday, February 7, 2013 5:01:39 PM(UTC)
SandraK
Held power connection from one side of water valve to other and pushed the water in door button and the water went into the ice maker. Now there is ice, but ice maker won't push it out.
#4 Posted : Friday, February 8, 2013 1:55:22 PM(UTC)
That means the ice maker itself is bad. The correction is to replace the ice maker. GE has redesigned the ice maker and the new ice maker can look different but this is direct replacement part.
- The ice maker Part number: WR30X10093
SandraK
#5 Posted : Friday, February 8, 2013 2:54:41 PM(UTC)
SandraK
Thanks Gene, but I wound up calling a repair person because the freezer started warming up and wasn't as cold as it used to be. Turns out there's a leak in the system and it is low on Freon. He said the thermostat in the ice maker won't let it fill if the temperature is not low enough to freeze the ice. Anyhow, that repair means new coils at six hundred dollars so we're buying a new fridge. Thanks again for your help. :)
#6 Posted : Friday, February 8, 2013 4:40:13 PM(UTC)
You are welcome. Good luck with a new refrigerator. Don't by any one made by LG or Samsung.
Guest (4)
Sandy (Dryer Repair)
by sandrakani 3/23/2015 10:08:14 AM(UTC)
Sandy (Washer Repair)
by Jeffry T 3/9/2012 12:58:49 PM(UTC)
sandy dishes (Dishwasher Repair)
by kxf0612 7/2/2009 9:26:26 AM(UTC)
Upper level does not get washed - sandy residue on glasses, etc (Dishwasher Repair)
by JayeLesley 12/27/2007 8:00:55 AM(UTC)
