nancybillj
#1 Posted : Wednesday, February 6, 2013 7:32:59 AM(UTC)
nancybillj
I am ready to replace the door switch and the wiring harness. I need instructions on how to do this. Do I go in from the top or back.
#2 Posted : Wednesday, February 6, 2013 5:29:20 PM(UTC)
Hello,
Most likely you have to do it from the front. The instructions are attached to the post. Look at the door lock picture bellow. If the old part looks exactly the same then you don't need a new wiring harness.
- The door lock assembly Part number: 131763202
- The wiring harness Part number: 134606800
Here are the breakdown diagrams and Parts for Frigidaire ATF6000ES1 Washer - AppliancePartsPros.com
File Attachment(s):
Removing the door safety switch.doc (430kb) downloaded 10 time(s).
nancybillj
#3 Posted : Thursday, February 7, 2013 7:41:21 AM(UTC)
nancybillj
Ok, thanks for the info on the door switch removal. When I ordered the new part, appliancepartspros said I had to have a new wiring harness and when it arrived, it had a lot more wires and hook ups than are shown in your diagram. To replace the whole harness, do I need to go in from the top or can I do it from the front?
#4 Posted : Thursday, February 7, 2013 1:07:45 PM(UTC)
What is the part number of the wiring harness you ordered?
In order to replace you have to remove the top panel too.
