willow5000
#1 Posted : Tuesday, February 5, 2013 10:51:32 AM(UTC)
willow5000
Bought new heating element about 3 months ago. It worked great.
Now - no heat. It runs no problem, just doesn't heat.
After the heat went out, it came back the next day (but not as hot as usual), and today there is nothing at all.
What do I check? what could be the culprit?
thanks
#2 Posted : Thursday, February 7, 2013 1:41:00 AM(UTC)
Parts for Whirlpool LER8648PW0 Dryer - AppliancePartsPros.com
See the attachment for the wiring diagram.
I would start by checking the heating element with a meter.
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 8 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and touched the case. This could cause what you describe and now the element is burned out.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
File Attachment(s):
LER8648.pdf (250kb) downloaded 4 time(s).
willow5000
#3 Posted : Thursday, February 7, 2013 11:11:21 AM(UTC)
willow5000
Thank you so much,
I've determined that it is the timer. I even opened it up, and it is nicely burned out in one corner. Do you know why this happens? I mean it's only copper connectors inside; why would it burn out all of a sudden?
Do you know if it would be possible to just replace the burned out metal parts on the inside?
#4 Posted : Thursday, February 7, 2013 11:58:28 PM(UTC)
[COLOR="Blue"] burned out in one corner. Do you know why this happens? I mean it's only copper connectors inside; why would it burn out all of a sudden?[/COLOR]
It probably did not burnout all of a sudden, it probably took some time.
What can happen is that the contacts can get dirty/pit over time. This pitting causes there to be some resistance between the contacts. When current passes through the contacts, heat is generated. This further degrades the contacts and so on and so on till the contacts fail.
[COLOR="Blue"]Do you know if it would be possible to just replace the burned out metal parts on the inside?[/COLOR]
I do not know of ant place that sell the timer's inmternal parts.
Electric Whirlpool Dryer - no Heat! (Dryer Repair)
by willow5000 2/5/2013 10:51:32 AM(UTC)
