jonellem
#1 Posted : Sunday, February 3, 2013 7:27:46 PM(UTC)
jonellem
Hi- Please advise. My gas dryer all of a sudden wouldn't heat. On most forums it said the igniter might be the issue. Easy to replace- so I did and cleaned the lint out of every nook and cranny in the dryer. Put the dryer back together and it still won't heat. I look through the little peep hole on the bottom of the dryer and the igniter and area around it turns red....but it never heats up. What would I replace next ? Some of the posts say it might be the coils ? Looks like I can buy the coils OR a coil kit ? I don't know what the difference is ?
Thanks-Jonelle
Simon / APP Team
#2 Posted : Monday, February 4, 2013 1:12:19 PM(UTC)
Simon / APP Team
Groups: APP Team
HI.
If the ignitor gets hot and then turns off you need to replace the control coils kit which is the same as the coils
Part number: 279834
Part number: 279834
Use the video clip for the instructions.
Post the results.
Simon.
