2 Pages12>
pharmadennis
#1 Posted : Thursday, April 16, 2009 8:01:55 AM(UTC)
pharmadennis
Machine was washing/agitating, I noticed the clothes soaked, Took machine apart, coupler is fine, Took out motor and shaft and put on the floor, motor engages clutch (I hear click) the clutch spins (clockwise looking down) and I am able to hold the shaft still during this "test" when I close lid, clutch appears ok, no broken parts noticed. Help would be appreciated. Thanks
#2 Posted : Thursday, April 16, 2009 12:30:45 PM(UTC)
Put it back together. Start the spin cycle. Wait until the water drains out, lift the lid up for a few seconds and close it back. If it will start spinning then the problem is a bad timer.
- The part number for the timer is AP3100292
pharmadennis
#3 Posted : Friday, April 17, 2009 5:08:20 AM(UTC)
pharmadennis
Thanks for the advice!!! Is there any chance that the drive block has failed?
Also, the top of the cabinet lacks clips and is fastened with screws in the front corners from the inside. Stupid design!! I will test the timer the way you described but what is the best way to take the top off this machine in the event I want to check the drive block and have to remove the basket? Thanks Again!!
#4 Posted : Friday, April 17, 2009 2:52:57 PM(UTC)
The top of the cabinet is not removable. I'm afraid you took it apart in a wrong way. The instructions are attached to this reply.
File Attachment(s):
How to remove the washer cabinet.doc (25kb) downloaded 27 time(s).
pharmadennis
#5 Posted : Saturday, April 18, 2009 3:24:39 AM(UTC)
pharmadennis
Gene, Thanks for your help so far. I didn't take the cabinet apart once I saw how it was put together so I waited for your answer. I did all my initial "looking" with the machine lying down. Thank you very much for the instructions. I am going to put it back together and test the timer the way you indicated. I do have a question related to this as I am trying to get a better understanding of this thing. As indicated in my initial posting, when the timer is in the spin position the motor does run yet there is no spinning of the basket. I thought the timer was only involved in making electrical contacts to different components so I proceeded to look for something mechanical in nature related to the failure. Should I check the drive block while I have this apart? Thanks for your wisdom on this thing. Dennis
#6 Posted : Saturday, April 18, 2009 3:21:56 PM(UTC)
Hi Dennis,
The transmission in this model is a neutral drain what means the washer drains first and then the timer should pause for a few seconds to engage the transmission and start to spin. If the timer does not do it then the timer is bad.
If there is nothing wrong then you can check the drive block.
pharmadennis
#7 Posted : Saturday, April 18, 2009 6:06:27 PM(UTC)
pharmadennis
Gene, Once again thanks for your knowledge and guidance on this. Having the cabinet off per your instructions I decided to take a peek at the drive block while it was open. I took the spanner nut off to get a look at the grooves in the drive block and they appear fine and engaged with the tabs. Thanks for your explanation on the timer as it has helped me understand what is going on here. I will order one and let you know what happens. Gene thanks again. Dennis
#8 Posted : Sunday, April 19, 2009 1:59:39 AM(UTC)
Remove pump from the motor and turn the shaft clockwise. When it engages spin,if it is hard to turn, you have dragging brake shoes, if easy to turn, you have a busted spin tube paw that engages the clutch. Post results.
pharmadennis
#9 Posted : Monday, April 20, 2009 4:07:37 PM(UTC)
pharmadennis
Well! I put the thing back together to test the timer as noted above and the thing is running fine. ??What the heck??? Is it possible that a real heavy load of towels will not spin? I noticed the soaking wet load when I had a load of towels in there. Is it possible that the break shoe may be dragging slightly and in combination with a heavy load it just can't get going? Let me know. Would it be wrong to put a large load in it to see what happens? Thanks for your help!!! Dennis
#10 Posted : Monday, April 20, 2009 8:01:32 PM(UTC)
Some time things are just unexplainable. Keep use the washer and hopefully it would not happen again.
Guest (5)
2 Pages12>
