SCOTT4
#1 Posted : Saturday, February 2, 2013 7:47:15 AM(UTC)
SCOTT4
I removed the drum and got to the burner assy, when I turn the dryer on the igniter does not even warm up. I don't have an ohm meter. I assume the igniter should be glowing?
SCOTT4
#2 Posted : Saturday, February 2, 2013 10:50:57 AM(UTC)
SCOTT4
I figured it out, I made a jumper wire and jumped the thermal fuse and was able to determine the fuse was bad...popped a new fuse in and I'm back in buisness.
