red&green
#1 Posted : Saturday, February 2, 2013 10:43:44 AM(UTC)
red&green
Have slow leak around drain act shaft. If its not one thing it' another! does the shaft have a o ring on it or not How is this shaft sealed?:mad:
#2 Posted : Sunday, February 3, 2013 2:29:06 AM(UTC)
Parts for GE GSD2200Z02WH Dishwasher - AppliancePartsPros.com
The shaft has a seal.
Take a look at Motor-Pump section.The seal is item 417.
You will also need a new Push-on Nut (item 415)
Take some pictures or make a diagram of the solenoid and springs so uou know where they go.
Remove the C-clip (item 413), be careful not to loose it.
Then remove the solenoid assembly.
Remove the push-on nut and the seal, taking note of how they go on.
Clean the shaft and the seal seat if there are calcium deposits/rust.
Install the new seal and nut. I like to give the seal a light coating of lithium grease.
The reinstall the solenoid and springs.
