Please help how do i troubleshoot...to find if its a relay or a compressor??? Thank you
We need more info to help
hello thank you for your reply ...not sure what info you need..fan seems to work. tried putting it in diagnostic mode but really not sure what i am doing
oh it just stopped cooling..diddnt freeze over or notice any noises
Check your compressor in the back.
how do i check the compresser
Remove the back panel and feal the compressor,should be warm and vibrating.
yes it is warm with slight vibration
If it clicks once in a while and stops vibrating, you have a bad start device #8201786, just use one of the larger start devices by folowing the directions included.
