laser_doc
#1 Posted : Wednesday, January 30, 2013 8:58:55 PM(UTC)
laser_doc
[FONT="Calibri","sans-serif"]I have a Frigidaire front load washer modelnumber LTF2940FE0. There is[/FONT] water running out of what appears to be a drain holeat the front of the tub all the way down at the bottom. I removed the front clamp from the doorgasket so I could inspect beneath the gasket but it is completely dry. The water starts to leak from the drain holewhen the water level in the drum reaches about 2 inches. Where is that water coming from?
#2 Posted : Thursday, January 31, 2013 2:49:57 PM(UTC)
Hello,
Open the door and carefully inspect the bellows for any cracks.
Remove the bottom access panel and observe everything while the washer is running a load.
Post the results.
Here are the breakdown diagrams and Parts for Frigidaire LTF2940FE0 Washer - AppliancePartsPros.com
laser_doc
#3 Posted : Thursday, January 31, 2013 10:04:24 PM(UTC)
laser_doc
Thank you for the quick reply Gene. With the access panel removed and the washer running through a cycle, the water is running out the drain hole I described in my post, at the extreme front and the extreme bottom of the tub. I inspected the bellows for cracks or tears, and I removed the front bellows clamp and peeled the bellows away from the front panel.. dry as a bone underneath. Unfortunately there isn't enough detail in the parts diagram to see the drain hole in the tub that I am talking about.
#4 Posted : Friday, February 1, 2013 12:03:45 PM(UTC)
Did you mean the hole in the outer tub where the drain hose (#41 at the diagram) is connected to?
laser_doc
#5 Posted : Friday, February 1, 2013 8:20:14 PM(UTC)
laser_doc
No, the hole for the drain hose is off to the right and set back a few inches. This is bottom dead center, at the extreme front of the tub. And there is what appears to be a channel molded into the bottom of the tub, running along its centerline from rear to front and terminating at this hole.
#6 Posted : Tuesday, February 5, 2013 2:01:44 PM(UTC)
Can you post a picture of it? It might help.
laser_doc
#7 Posted : Thursday, February 7, 2013 11:43:51 PM(UTC)
laser_doc
Here are three shots, Gene. In No 1, I am pointing at the hole that the water is coming out of. The other two shots show the hole at different angles and also the channel leading up to the hole.
laser_doc attached the following image(s):
#8 Posted : Friday, February 8, 2013 1:45:43 PM(UTC)
Looks like the front half of the outer tub is leaking. The correction is to replace the front shell.
- The front shell Part number: 134362000
laser_doc
#9 Posted : Sunday, February 10, 2013 7:49:52 PM(UTC)
laser_doc
Groannnn.. that does look like more fun than I was hoping to have with this. I do appreciate your help Gene,
#10 Posted : Monday, February 11, 2013 1:17:03 PM(UTC)
You are welcome. Yes, this repair is not a simple one.
