cksanabria
#1 Posted : Tuesday, January 29, 2013 3:03:08 PM(UTC)
cksanabria
Hello I am new to board but a long time reader, I have fixed many things with this boards help. Anyway My double oven the top will not heat but the lower oven heats fine. My lights and clock work but no heat. The high limit has continuity the elements are good. What should I check next? thermo, relay?
I hear it click when turned on then about 5 seconds later it will click again, Any help is greatly appreciated.
I have no error codes.
Chris
#2 Posted : Wednesday, January 30, 2013 12:51:16 PM(UTC)
Hi Chris,
If the high limit checks good then the only part left is the oven control board. Are you sure that both Bake and Broil stopped to work at the same time?
- The control board Part number: 7601M286-60
cksanabria
#3 Posted : Wednesday, January 30, 2013 4:04:15 PM(UTC)
cksanabria
yes sir both quit at same time is that a relay near the high limit? the high limit is just a continuity test correct?
Thank you!
Chris
#4 Posted : Wednesday, January 30, 2013 8:29:59 PM(UTC)
Yes Chris, if there is closed circuit shown then the high limit is good.
This relay is not shown on the wiring diagram as a separate part and I can not determine what is the function of it. So far I would suspect the control board.
cksanabria
#5 Posted : Thursday, January 31, 2013 5:42:33 AM(UTC)
cksanabria
DO you know or how could I find out the function of the relay aux dbl part #
74009405 ? can I test before I purchase a $300+ control board? or should I just replace control board?
Thank you for your advise
Chris
#6 Posted : Friday, February 1, 2013 2:31:01 PM(UTC)
Hi Chris,
Try to track down the wires connected to this relay and post the result. You also can order the control board from APP and return it if it would not fix the problem.
Where did you find $300+ price for this part? APP price is $259.70
cksanabria
#7 Posted : Thursday, February 7, 2013 4:47:05 PM(UTC)
cksanabria
I cant really track the wires with all the others in the way. But there are two yellow and two red. one of each look cloth wrapped and the others plastic. Probably does not help. Everyone shows part to buy but not on wire diagram.
Should I just replace the control board? or test some how the DBL aux relay?
Thank you so much in advance
Chris Trying to save a buck:)
#8 Posted : Friday, February 8, 2013 1:57:52 PM(UTC)
I would order the control board and give it a try.
cksanabria
#9 Posted : Saturday, March 9, 2013 7:22:32 AM(UTC)
cksanabria
Thank you gene the Electronic control board fixed my problem
Chris:)
#10 Posted : Monday, March 11, 2013 1:15:26 PM(UTC)
You are welcome Chris. I'm glad to hear it's up and running.
