Hello there, my ice maker when it is start it works for 3 or 4 circle, after it is stop and I can see inside there are some thin ice everywhere, looks it is continue cooling but water is stop to send,if we say the water inlet valve is broken, why it can work at starting and the first time I open it, I found the water level sensor there is a wire broken, I reconnect the wire, but it is still the same situation, please help me, any info will be very thanks.
