garymcgill
#1 Posted : Wednesday, January 30, 2013 6:21:30 AM(UTC)
garymcgill
The unit stopped making ice. I removed the icemaker which had no water in it and found that the water line was frozen. I defrosted the waterline and put the maker back together and it ran 1 cycle (filled w/ water and dumped ice) but did not refill the tray a 2nd time...I see the waterline is frozen again. I'm not sure if my tray is malfunctioning or perhaps the water valve is not sealing correctly and allowing a trickle of water to freeze the line...any ideas?
garymcgill
#2 Posted : Thursday, January 31, 2013 5:30:36 AM(UTC)
garymcgill
For any that are interested or having a similar issue, I changed the dual water valve and this solved my problem...:)
