torohockey
#1 Posted : Tuesday, January 29, 2013 3:30:32 PM(UTC)
torohockey
Dish washer has 2 issues, first it does not always fill with enough water to
run the jets. The second problem is it slowly drains during the wash and rinse cycles.
#2 Posted : Wednesday, January 30, 2013 12:59:06 PM(UTC)
Hello,
Where is the drain hose connected to?
What is the complete model number of the dishwasher?
torohockey
#3 Posted : Saturday, February 2, 2013 11:17:42 AM(UTC)
torohockey
Model # 665.1321 2k901
torohockey
#4 Posted : Saturday, February 2, 2013 11:18:46 AM(UTC)
torohockey
Hello,
It goes through a hole in the floor to a drain line in the joists. Im going to
rerought the drain to the garbage disposal to see if that helps. The only thing is this machine has ben installed and working properly for more than a year so i dont think thats the issue.
Read more: http://forum.appliancepartspros...water.html#ixzz2Jm6xOcA7
http://forum.appliancepartspros.com
#5 Posted : Tuesday, February 5, 2013 1:17:35 PM(UTC)
The drain hose should go at least 20" above the floor.
