sgm1115
#1 Posted : Monday, January 28, 2013 4:32:34 PM(UTC)
sgm1115
i can see the drum spinning but it dose not seem to get up to full speed . :confused: could it be the clutch is just worn but not broken ?
#2 Posted : Tuesday, January 29, 2013 2:02:19 PM(UTC)
Hello,
Remove the washer cabinet and bypass the lid switch. Observe the clutch hub while the washer is in the spin mode. If the hub is spinning but the basket is not or it's spinning slower than the clutch hub then the clutch is bad.
- The clutch assembly Part number: 285785
Part number: 285785
