My Viking gas oven door will not close. Does anyone know of a way I can fix myself without calling a repair guy?
Thanks,
McDoo
Check the door hinges for any damages.
Unfortunately I do not have any access to the Viking break down diagrams or parts list.
Thanks Gene. Do you konw how I would remove the door?
Open the door completely and move the actuator on the door hinge until it locks up. Grabbing the door from both sides, pull it up to release hinges.
1. are the actuators chrome/bright metal?
2. after removing the door, how do I know if the hinge is defective, and how do I replace them?
3. will doing this tighten the oven door seal and keep the door from falling down onto my toes again?
If you can take pictures of the hinges and post them it might help.
![UserPostedImage](http://file:///Users/Manya/Pictures/IMG_1843.JPG) Please advise how to do send photos. I don't see a way to embed images into the post. I have some to send at low resolution.
Post it as an attachment.
Thanks for the photo attachment instructions. I hope they clarify the situation. dropsy attached the following image(s):
You have to move the lever "A" to position "B" to lock the hinge. Grab the door with both hands and lift it up to release the door hinges. Gene. Gene attached the following image(s):
