Reel Captain
#1 Posted : Tuesday, January 22, 2013 6:57:19 AM(UTC)
Reel Captain
A few weeks ago a buzz started coming from the compressor area(underneeth) and now it is more requent and there is a click after it happens. I have two of the same models side by side. The one that is not clicking has more heat coming from the coil area.
Simon / APP Team
#2 Posted : Tuesday, January 22, 2013 2:28:49 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
What you hear is the compressor trying to start. Check if the condenser motor is running (one next to the compressor) and if it does - cool down the compressor, remove the start components and using the multimeter check compressors three contacts for continuity between them and the ground.
If there is continuity between three pins and no continuity to the ground - replace the starting device
Part number: 67005560
If there is no continuity at the compressor contacts or there is continuity to the ground, that indicates bad compressor.
Here are the breakdown diagrams and 02-Compressor parts for Amana ABC2037DTB - AppliancePartsPros.com
Use the opportunity to clean the condenser coils while you are there.
Post the results.
Simon.
Reel Captain
#3 Posted : Thursday, January 24, 2013 7:12:03 PM(UTC)
Reel Captain
I installed a new compressor starting device, but still the buzz click with the new starter and capacitor. I guess I am headed for a new compressor? Are there any other options before I bite the big one?
I guess now I know it's a bad compressor I will like the buzz click to know the compressor is not tits up and my beer will be getting warm.
jenniferatkins
#4 Posted : Friday, January 25, 2013 12:32:27 AM(UTC)
jenniferatkins
Have you checked the compressor with multimeter? if not then check it. I think it may no be dead.
Reel Captain
#5 Posted : Friday, January 25, 2013 8:05:29 AM(UTC)
Reel Captain
Hello,
I did check the compressor as follows:
VAC in 118V
Continuity between all three poles, and none to ground
Ohms between top and side poles rangeing from 4.8 to 12
Is there any other test to determine bad compressor?
Simon / APP Team
#6 Posted : Friday, January 25, 2013 8:54:51 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The compressor could still be bad even if it passes the electrical test.
Try to install the "3in1" booster just to turn the motor if it's not completely out.If the compressor will kick on replace it with the standard starting devise.
Part number: TJ90RCO410
Post the results.
Simon.
Reel Captain
#7 Posted : Friday, January 25, 2013 9:15:52 AM(UTC)
Reel Captain
Hello,
Is the 3 in 1 a perminant fix for a hard starting compressor? My compress will start from time to time with the new starter and capistor installed.
Lance
Simon / APP Team
#8 Posted : Friday, January 25, 2013 10:20:41 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The 3 in 1 is not a permanent solution, unless the factory specified devise doesn't work and you technically have nothing to loose.
Having the 3in1installed permanently may cause start winding burn out, but nobody can tell you how long before it'll happens.
Post the results.
Simon.
Reel Captain
#9 Posted : Friday, January 25, 2013 10:31:09 AM(UTC)
Reel Captain
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Post the results.
Simon.
Great to Know! I have nothing to loose.
Simon / APP Team
#10 Posted : Friday, January 25, 2013 10:36:49 AM(UTC)
Simon / APP Team
Groups: APP Team
Good luck.
Simon.
Guest (5)
