Washer will not agitate, spin or drain. When put into wash or spin cycle the washer hums. Any suggestion where to start? Clutch, gear, motor?
Groups: APP Team
Hi. If the motor runs check the motor coupling Part number: 285753A
Use the video clip for the disassembling instructions. If the motor is not running - remove the drain pump from the motor shaft and check if the pump is not frozen. Next take the motor out, bypass the lid switch and see if the motor will run. Next - check the motor capacitor Part number: 8572717
Also you should check the wire harness and the motor plug contacts. Post the results. Simon.
