Rank:: Member
Double oven was installed at the time home was built, 2005. Display went totally black, keys beep when pressed, lights come on when door is opened and light comes on when light button is pressed, but nether oven works. Help!
Groups: APP Team
Rank:: Member
Originally Posted by: Simon / APP Team Simon, How do I get the control panel off to replace the control board? Pete
Groups: APP Team
Hi.
Open lower oven door. Take out two screws at the bottom one on each side of the side trims.Pull the trims out and down to remove. Remove two screws one on each side of the control panel, pull it up and out. Make sure to turn the power off before doing anything.
Simon.
Rank:: Member
I installed the new board & the oven came to life! Installation was very easy. Note that the old connector on the ribbon cable will not fit on the new board. The new board comes with a new black connector attached on the board. Remove the new ribbon cable connector from the board, carefully slip off the old connector from the ribbon cable & slip on the new one. The ribbon cable will now lock on to the board.
Groups: APP Team
Thank you for shearing with us useful information.
Simon.
This one is a lifesaver! I was just about to have mine sent to the local repair shop that charged an arm and a leg for repairs. Good thing I found this and did the tinkering myself. Thanks!
Groups: APP Team
