JReekers
#1 Posted : Tuesday, January 22, 2013 5:54:46 AM(UTC)
JReekers
my dryer will start and will dry the load half way but stops and if you let it sit a little bit you will be able to stat it again and you can mess with the buttons all you want but wont start unless it sits for 5 minuts or so the start relay makes the clicking sound every time you change the settings or open the door
Simon / APP Team
#2 Posted : Tuesday, January 22, 2013 1:03:29 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Based on the information you have provided the motor is overheating and the overload opens.
First check if the motor simply needs to be clean of lint, if not - replace the motor Part number: 279827
Part number: 279827
Use the video clip for the instructions.
Post the results.
Simon.
