Triple g
#1 Posted : Tuesday, January 22, 2013 1:03:08 PM(UTC)
Triple g
The compressor and condensor fan run/ freezer gets cold but the evap fan doesn't run in the freezer. How do I check if the fan is bad?:confused:
Simon / APP Team
#2 Posted : Tuesday, January 22, 2013 3:37:45 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Remove the rear cover in the freezer to get to the evaporator fan and check if it's getting 120VAC and the fan blade not jammed. If there is correct voltage and the blade is free - replace the motor
Part number: 4389155
Here are the breakdown diagrams and Air Flow and Reservoir parts for Whirlpool KSSS42DBW00 - AppliancePartsPros.com
Post the results.
Simon.
Evap fan not running, fridge beeps (Refrigerator & Freezer Repair)
by jsstabby 3/31/2014 9:54:52 AM(UTC)
GE Frig Evap Fan not running (Refrigerator & Freezer Repair)
by fredfarm 2/22/2013 1:13:54 PM(UTC)
Evap fan not running (Refrigerator & Freezer Repair)
by khaag27 4/15/2010 11:19:19 PM(UTC)
