Big Boy
#1 Posted : Tuesday, January 22, 2013 9:31:40 AM(UTC)
Big Boy
HI, My son was replacing his timer. He removed all the wires and now can't remember which wirer goes where. I can't make heads or tails of the wiring diagram for it. Can anyone help me out? Thanks
#2 Posted : Wednesday, January 23, 2013 2:03:47 AM(UTC)
I am not sure what the problem is.
Could you be more specific as to what the problem is reading the wiring diagram?
It is really the only info available on how to hook up the wires.
Big Boy
#3 Posted : Wednesday, January 23, 2013 2:46:13 AM(UTC)
Big Boy
Thanks I.think I got it.
franknbear
#4 Posted : Monday, November 18, 2013 3:56:41 PM(UTC)
franknbear
Hey, I had about the same problem. While working on a stacked unit the control panel kept dropping off and hanging by the wires. Then I found 8 of them had pulled loose when I went to put it back together and I also can tell from the wiring diagram which wire goes where.
How did you solve it?
