I just received a clock temperature control replacement part from Appliance Parts Pros. Unfortunately, there were no installation instructions included.
This is a 1998 Frigidaire Gallery Professional Series electric oven. If someone can help me find instructions online or give me some insight into installing this part, I would be grateful.
Hello,
Pull the range out of the wall and remove the control panel rear cover. The clock should be secured to the frame with 4 screws.
Gene,
Do you mean the front cover?
Gene. Hi Marsha, I double checked it - it says "rear". Gene.
