JetFla
#1 Posted : Wednesday, April 1, 2009 12:55:39 PM(UTC)
JetFla
I have a GE XL1800 spacemaker microwave. I began making a humming noise (louder than usual) when cooking. After a week or two, it stopped heating. All of the other features work fine. After reading your forum, I decided to replace the magnetron. I took the old one off and saw that it had a burn hole (apart from the regular hole) in the end. The first mag GE sent did not heat and made the humming soud again. I had GE send me another one and I installed it. It sounds fine but still no heat. I rechecked all of the other features and they still work. I can hear the power cycling on and off in the defrost mode. I checked the connections, wires etc. and it looks ok. Anything else I might be missing? Thanx in advance.
applianceman
#2 Posted : Wednesday, April 1, 2009 5:41:48 PM(UTC)
applianceman
Did you replace the diode? Often when the magnetron tube is bad so is the diode and the microwave will not heat if the diode is bad. Locate the capacitor on the capacitor you should see the diode attached one terminal of the capacitor and other end to ground. Replace it if you haven’t already. Microwave Repair Guide
JetFla
#3 Posted : Thursday, April 16, 2009 11:00:16 AM(UTC)
JetFla
Hey Applianceman,
Thanks for the info. After reading other posts, I was thinking the diode could be bad as well. I gave it a visual inspection and there was no burned marks, cracking or anything else I could see on the diode exterior. I wanted an expert opinion before I changed it out. Let's hope that's it or it's the landfill for this thing. Thanks again.
JetFla
microwave won't heat (Microwave Repair)
by Suefink 2/13/2013 2:53:07 PM(UTC)
Microwave won't heat (Microwave Repair)
by gkronenberger 11/24/2012 5:02:07 AM(UTC)
brand new microwave won't heat sensor error (Microwave Repair)
by redcellocase 6/8/2012 7:47:31 PM(UTC)
by lilbart 1/17/2012 9:24:27 AM(UTC)
by frankish 12/8/2011 12:38:07 PM(UTC)
Whirlpool Microwave won't heat (Microwave Repair)
by Wendy Porter 12/2/2011 5:45:04 PM(UTC)
by vangoy 12/1/2011 5:03:01 PM(UTC)
by jlune423 6/28/2011 9:22:36 PM(UTC)
GE Profile Microwave won't heat? (Microwave Repair)
by bill007 3/3/2011 4:47:45 PM(UTC)
by mtorrey 2/12/2011 11:41:56 AM(UTC)
Microwave Won't heat food and turntable doesn't rotate (Microwave Repair)
by PaulieMo 1/24/2011 10:38:46 AM(UTC)
Microwave won't heat/Loud buzzing (Microwave Repair)
by grami 8/11/2010 5:14:13 AM(UTC)
Kitchen Aid Microwave Won't Heat Food (Microwave Repair)
by lmcalpin 7/20/2010 9:16:35 AM(UTC)
Microwave Won't Heat (Microwave Repair)
by cfairban 1/18/2010 10:21:36 AM(UTC)
Microwave won't heat, over the range Mcrw. (Microwave Repair)
by mbradyla 1/15/2010 10:52:20 AM(UTC)
