kcnowlin
#1 Posted : Wednesday, January 16, 2013 10:49:44 AM(UTC)
kcnowlin
I have 3 of these coin-operated washers at an apartment complex along with a similar Kenmore. The other 3 all fill to the top of the agitator during wash & rinse cycle, while this particular one fills to only about 6" below top of agitator. Is there a way to adjust water level?
Simon / APP Team
#2 Posted : Wednesday, January 16, 2013 2:32:19 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
The water level switch is factory preset and should not be tempered with.
Open the cabinet (make sure the tub is completely empty),remove the pressure hose from the switch and blow into it to clean it.
If that not going to help - replace the water level switch
Part number: W10339019
Here are the breakdown diagrams and Rear Panel parts for Roper RAK2751KQ0 - AppliancePartsPros.com
Simon.
