mark val
#1 Posted : Wednesday, April 15, 2009 7:56:05 PM(UTC)
mark val
Fan keeps on freezing and will not drain ever few days
woodchuckie
#2 Posted : Wednesday, April 15, 2009 8:56:05 PM(UTC)
woodchuckie
Your drain tube must be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flush it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer.
LG ice maker fan freezing up (Refrigerator & Freezer Repair)
by daileydallas 9/12/2015 10:42:01 AM(UTC)
Freezer fan freezing up (Refrigerator & Freezer Repair)
by jerrysc1 9/5/2011 6:06:35 AM(UTC)
