Groups: APP Team
Hi.
Please provide more detailed description on the problem.
Simon.
Simon. Hi Simon: Not sure what else I can say other than the dishwasher does not turn on. I have checked the electrical outlet and there is power. I have not openned the system. Not sure what else to check. It doesn't matter what setting i put the dischwasher on, it does not seem to have any power going into the system. I was told that it might be the control panel. Do you have any other troubleshoting receommendations.
Groups: APP Team
Hi. Open the kick panel, locate the junction box on the right and check the wiring connections inside. If it's good - replace the control board Part number: 154712101
