johnwartjr
#1 Posted : Thursday, January 10, 2013 11:48:06 AM(UTC)
johnwartjr
Greetings
My aged whirlpool dishwasher is leaking.
After watching it run, it is dribbling from where the metal motor bolts to the plastic housing underneath. I'm not sure exactly where in the area, but I took the front covers off beneath the dishwasher and ran a load, and water started dripping in this area.
A little internet searching brought this site up:
http://www.********************...om-motor-area-DU840CWDB3
It suggested I replace possibly 4 parts.
Is there any good way to narrow the part I need down? Or perhaps they are all good to replace on a dishwasher of this age?
I wouldn't mind ordering the sump, the seal and the seal assemblies, but when I start looking at $150 for the pump and motor itself, I start to question if it might be time to just replace the dishwasher. Of course, I don't know what 'modern' dishwasher is comparable to this one.. so I'd have to become an educated shopper.
The dishwasher we have now is adequate; and our home is more of a starter home, so I don't need anything super fancy as it would make the rest of our appliances appear cheap :)
Any guidance is appreciated!
NOTE: My link was altered when I post it - I apologize if I've broken any rules in posting this information. I would of course order the parts from this site instead of another to support it for helping me!
Simon / APP Team
#2 Posted : Thursday, January 10, 2013 2:39:25 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Most likely the leak is from the bad shaft seal. You need to replace the impeller kit Part number: 4386996
Here are the breakdown diagrams and Pump and Motor parts for Whirlpool DU840CWDB3 - AppliancePartsPros.com
Post the results.
Simon.
johnwartjr
#3 Posted : Friday, January 11, 2013 6:37:43 PM(UTC)
johnwartjr
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Post the results.
Simon.
Hi Simon
Is there anything else I should replace while I'm in there?
Simon / APP Team
#4 Posted : Sunday, January 13, 2013 12:27:27 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
That should be OK.
Simon.
johnwartjr
#5 Posted : Thursday, January 17, 2013 7:18:00 AM(UTC)
johnwartjr
The parts have arrived.
I am, however, unclear based on the diagram as to how I should proceed with replacing them.
I have the front panels off the lower part of the dishwasher, can I reach through the opening and do all the work? Or, should I unhook the dishwasher and pull the entire unit out of the kitchen cabinet?
Do I need to take anything apart inside the dishwasher, like removing the impeller?
Simon / APP Team
#6 Posted : Thursday, January 17, 2013 12:11:58 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You will need to remove the dishwasher, turn the water and power off.Disconnect the water inlet and drain lines.
Remove the lower spray arm and large nut in the center.
Pump and Spray Arm parts for Whirlpool DU840CWDB3 - AppliancePartsPros.com
Pull out the dishwasher, put it on the side, take off mounting bracket and sump hose clamp, remove the assembly.
Use an adjustable wrench to turn the disk mount assembly CCW.(Insert it inside).
Part number: 3369012
Pull off the impeller and both seals.
Reinstall new kit.Reinstall pump/motor back.
Simon.
