awvufan76
#1 Posted : 13 years ago
awvufan76
My oven is a year and a half old. the stove works bit the oven dont. im gettin no error codes.elements wont heat in bake broil or clean cycles. i have powee to elements when thesw settings are on but no heat.i am getting continuity on my elements...i am puzzled. please help me....thanks..:confused: sorry but the model # is WFE361LVB....thanks
Simon / APP Team
#2 Posted : 13 years ago
Simon / APP Team
Groups: APP Team
Hi.
Please check the model number and manufacturer, the one you provided doesn't come up.
Simon.
awvufan76
#3 Posted : 12 years ago
awvufan76
Sorry...WFE361LVB....the" w "looked like an "x".
Simon / APP Team
#4 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Hi.
Still missing one number after B.
Are you getting 240VAC to the elements? Please explain how do you measure the voltage.
Simon
jklawitter
#5 Posted : 12 years ago
jklawitter
I have a wfe381lvs and am having the same problems...no error codes, stove top and clock work fine but no heat to the oven. Sensor has been tested and is good. Please help.
Simon / APP Team
#6 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Hi.
If there is no bake or broil most likely the thermal fuse is blown Part number: 3196548
It's not very clear where is it (the diagram is not the best) but I think you should look under the top, behind the door latch. the video clip take you to the back of the range...you may check it too.
Here are the breakdown diagrams and Chassis parts for Whirlpool WFE381LVS1 - AppliancePartsPros.com
It's #26.
Simon.
Good luck. Post the results.
jklawitter
#7 Posted : 12 years ago
jklawitter
Thanks so much for your quick reply. I recognize that part...it's on the back side of the unit. I already had the back panel off trying to see if there were any wires that looked like they had shorted out and I remember seeing this particular piece on the back. Do you know what the ohms reading should be on the thermal fuse to determine if it's good or bad?
Simon / APP Team
#8 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Hi.
Take one wire off the fuse when checking.
You should read 0ohm.If it's open - replace it.
Simon.
jklawitter
#9 Posted : 12 years ago
jklawitter
I tested the fuse...it works. I have no idea what's wrong with this range....??
Simon / APP Team
#10 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
HI.
If the fuse is good you need a control board/clock
Part number: W10271740
For the white panel use W10271739
Simon.
