Originally Posted by: rozman  hi. i have a vintage 1985 GE dual wave system also and my light bulb in my microwave is not working. do you know where the light bulb is and do you have a manual that tells you how to replace it? I have just worked on a 1983 model and found that if you pull the unit out away from the wall you will find a little cover with one screw in it, remove the cover you will find the bulb.:)
We have the GE Dual Wave Microwave System as well. The heating elements in the oven are heating slowly. We know we will have to buy a new system soon but for now we are interested in giving this one a bit more life. Does the heating element part ( AP2031031) apply to both the top and bottom elements? The elements do not get red hot when we turn on the oven -- just kind of warm. Model # JKP62G0K3 Thanks! Dominique
Hi Dominique, If the both, broil and bake, elements are not getting red hot, then the problem most likely is a bad oven thermostat and/or the oven selector switch. Unfortunately both of them are no longer available. You may want to check the circuit breakers for the oven and the wires inside the control panel and on the back of the oven. Otherwise it's time for a new oven. Here are the breakdown diagrams and Replacement parts for General Electric JKP62G*K3 Electric range | AppliancePartsPros.comGene.
Originally Posted by: Gene  Gene, I saw you posting on replacing the light bulb in this particular GE microwave. I have theould you GE JKP67G*J3 with the same problem. Could you send me instructions on how to open the control panel so I can get to the bulb?
The light bulb can be behind the top grill or behind the control panel. Unfortunately I do not have more specific instructions for this model.
I have recently inherited this 1986 ish GE Dual Wave II oven and there is no manual to be found. I'm trying to use the self cleaning oven feature and cannot seem to get it figured out. This oven is in crazy need of a good cleaning. I would appreciate any suggestions that you may have. Thanks for any feedback. Debra
