jon_e
#1 Posted : Saturday, January 5, 2013 11:30:20 AM(UTC)
jon_e
I just replaced the clutch in a Kenmore washing machine. Now the washer does not drain, but goes right to spin and it tries to spin full of water. The motor makes no noise when it should be draining. So I don't think the pump is bad. Help!!:confused:
sidfink43
#2 Posted : Monday, January 7, 2013 5:06:34 PM(UTC)
sidfink43
This sounds like a timer issue but it may also be the wiring. If the motor is running and nothing is clogged it should be draining even while it is spinning.
You may not have connected the wiring to the motor switch correctly, so take the connection apart, clean all the contacts and make sure it goes on correctly
