Larry2250
#1 Posted : Monday, January 7, 2013 2:39:09 PM(UTC)
Larry2250
Washer & Dryer combo. Frigidare Model #GLTF1670AS0. I ordered a door lock switch and this did not help. I then removed the back and run some test. I have a locked drum and I cannot break it loose. Should I just trash this washer?
#2 Posted : Tuesday, January 8, 2013 3:04:18 PM(UTC)
Originally Posted by: Larry2250 Go to Quoted Post
...I have a locked drum...
Hi Larry,
How did you find it?
Which tests did you run?
Here are the breakdown diagrams and Parts for Frigidaire GLTF1670AS0 Washer - AppliancePartsPros.com
agitator and drum locked up (Washer Repair)
by Edward80 10/19/2012 6:43:13 PM(UTC)
