Motordoctor
#1 Posted : Friday, January 4, 2013 12:34:31 PM(UTC)
Motordoctor
Have a gas dryer that will heat for about 5 minutes, then the heat quits. It was working fine until it possibly got some water damage from Hurricane Sandy. It was on top of the washing machine so the water line was about 4 inches up from the dryer bottom. Any suggestions? I'm trying to fix this for a couple with children that are living in a shelter right now until their house gets power back to it. Thanks in advance.
Simon / APP Team
#2 Posted : Friday, January 4, 2013 3:51:18 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Based on the info you provided you should replace the control coils Part number: 5303931775
Here are the breakdown diagrams and Burner parts for Frigidaire FGQ332ES0 - AppliancePartsPros.com
Post the results.
Simon.
Motordoctor
#3 Posted : Friday, January 4, 2013 5:20:23 PM(UTC)
Motordoctor
Pardon my ignorance but where are those located? I didn't see them on the parts diagram you sent. I'm a motorcycle mechanic, this is the first appliance I've ever worked on.
Simon / APP Team
#4 Posted : Saturday, January 5, 2013 9:35:48 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
On the top of the gas valve. The double coil has an insert, when replacing make sure it's on the shaft.
Simon.
Motordoctor
#5 Posted : Saturday, January 5, 2013 5:58:01 PM(UTC)
Motordoctor
How do you access the Gas Valve? Do you have to remove the drum? I took the rear access cover off and couldn't see anything that looked like the part. I took the top off also. Tight quarters in there. I can look from the back down the gas inlet pipe but I can't access anything in there. Thanks again for your help.
Simon / APP Team
#6 Posted : Sunday, January 6, 2013 8:14:13 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You need to remove the top cover and front panel to get to the gas valve.Take three screws at the back out and slide the top back an inch and lift it off.
Controls / Rop Panel parts for Frigidaire FGQ332ES0 - AppliancePartsPros.com
Front Panel / Lint Filter parts for Frigidaire FGQ332ES0 - AppliancePartsPros.com
Simon.
Motordoctor
#7 Posted : Wednesday, January 9, 2013 5:29:14 AM(UTC)
Motordoctor
Thanks, I will have a look at it this weekend and report back. You've been extremely helpful.
Simon / APP Team
#8 Posted : Wednesday, January 9, 2013 9:24:11 AM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
