imhoff1
#1 Posted : Friday, January 4, 2013 9:03:43 AM(UTC)
imhoff1
After running the cleaning cycle, the oven doesn't heat up. I am ready to take it apart to see what is burnt out. Here is some specific information: We have tried the reset procedure (1. Slide the oven lock lever all the way to the left. 2. Turn the Selector to off and the temperature control fully counter clockwise. )
The odd thing is that if we turn on the cleaning cycle again, the lights on the panel turn on and the stove heats up quickly. But in normal operation the oven will not heat up, and the achieve temperature light does not go on initially. (Supposed to be on when temperature is set, and off when oven reaches that temperature.)
Does this specific situation ring a bell with anyone? (We have also tried turning off the breaker, etc. with no effect) Thanks for any help, including specific parts that I may need to order! Rob
Simon / APP Team
#2 Posted : Friday, January 4, 2013 10:02:36 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Please check and re post the complete model number of the unit.
Simon.
imhoff1
#3 Posted : Friday, January 4, 2013 10:32:12 AM(UTC)
imhoff1
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Simon.
KEMS378XBL1 serial no. XB2501367 / June 1992
Thanks, Rob
Simon / APP Team
#4 Posted : Friday, January 4, 2013 12:19:23 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
With oven set for BAKE and power off.
First check if the oven switch is on MANUAL not on AUTO contacts 2- 3 are closed.
Next: - latch switch continuity NC-C (3-1)
- thermostat 2-1, 8-7
- selector switch 1-B, 6-H, 2-3
Here are the breakdown diagrams and Control Panel parts for Whirlpool KEMS378XBL1 - AppliancePartsPros.com
Simon.
