Rick Shcchtx
#1 Posted : 12 years ago
Rick Shcchtx
Whirlpool gas oven and range are both taking longer than normal to ignite. On the range I turn the knob and have to wait 30 seconds or longer before gas is present then it will ignite. When it is lit the flames seem to be a little lower than normal. On the oven when I turn it on it takes over a minute before it will actually lite. This is Mod# WFG231LVSO. Any help is greatly appreciated.
Simon / APP Team
#2 Posted : 12 years ago
Simon / APP Team
Groups: APP Team
Hi.
Most likely you have there a bad pressure regulator and may be weak bake ignitor. You can check if you have the amp meter the amp draw of the ignitor (3.25 amp min.)
The pressure regulator Part number: 98007411
Here are the breakdown diagrams and Manifold parts for Whirlpool WFG231LVS0 - AppliancePartsPros.com
Post the results.
Simon.
