Mike_Brokenwasher
#1 Posted: : Thursday, January 3, 2013 5:25:53 PM(UTC)
Mike_Brokenwasher
Let's try posting the problem again. The leak appears to have been the center post gasket pn: 383727. Although the center post gasket is fixed in the outer tub it appears to also be intended to form a seal for the inner tub as well. The inner tub is rusted at that point of contact and is not going to create an effective seal. Is this gasket supposed to provide a seal for both tubs?
fairbank56
#2 Posted : Thursday, January 3, 2013 6:15:25 PM(UTC)
fairbank56
Groups: Expert
No, it does not. Water flows freely between the tubs.
Eric
Mike_Brokenwasher
#3 Posted : Thursday, January 3, 2013 6:31:15 PM(UTC)
Mike_Brokenwasher
Thanks, there is a lot of debris up the shaft to the drive block I was concerned about the bearings.
