2 Pages<12
#11 Posted : Tuesday, February 9, 2010 3:30:13 PM(UTC)
Originally Posted by: simonboyce Go to Quoted Post
Hi Gene: I see you can buy the motor without the pump, and it's a lot cheaper. Would you advise me to try that?
No, because it is not clear what exactly is wrong. You also will need the impeller kit and this job is much more complicated.
simonboyce
#12 Posted : Thursday, January 3, 2013 11:02:44 AM(UTC)
simonboyce
Hi Gene: Digging around inside my dishwasher again. Kenmore model number 66515822000. I'm trying to remove the pump/motor assembly, which I did before per your instructions. But this time it seems to be stuck. I've rotated the clamps that hold it in place, removed the wiring and check valve, but I can't lift it up out of the hole from inside the dishwasher. Any suggestions? Thanks, Simon
#13 Posted : Thursday, January 3, 2013 2:05:34 PM(UTC)
Hi Simon,
Try to push it up from under the dishwasher. Do it on the bottom of the motor. It did work for me many times.
simonboyce
#14 Posted : Thursday, January 3, 2013 2:19:21 PM(UTC)
simonboyce
Hi Gene: Thanks as always for your advice. I managed to get it out eventually - just well and truly stuck in there. Really appreciate this site - super helpful. Cheers, Simon
#15 Posted : Thursday, January 3, 2013 2:30:44 PM(UTC)
You are welcome Simon. If there is anything elese we can help you with, just drop us a line.
2 Pages<12
