I need the part numbers for a Kenmore Elite Oasis he washer. The parts that I need are for the drain pump,recirculation pump, and for the motor. Thanks to anyone who can provided these numbers for me. My repair man is stating that I need a new motor and recirculation pump and I want to see how much it would be to replace these on my own.
I tried to locate part numbers based on the model number you supplied, but that model doesn't seem to be recognized. However, the recirculation pumps appear to be in the $50-$60 range, while the motors seem to run under $150. Hope that gives you a ballpark.
The model number is not recognized on this site (too bad, part prices here are very good) but it is recognized on the SearsParts site. You can find your part numbers and prices there.
The part number for the drain pump is AP4365341 and you can buy it for $73.35 The part number for the recirculation pump is AP3964217 and you can buy it for $49.51 The motor consists of two separate parts (stator and rotor) which are pretty expensive and are not simple to replace. The part number for the stator is AP3873407 and you can buy it for $157.23 The part number for the rotor is AP3882831 and you can buy it for $149.96 Gene.
I would like to thanks everyone for looking for the parts for me and suggesting searsparts. Special thanks to Gene.
