ronpmann
#1 Posted : Wednesday, April 15, 2009 5:45:56 AM(UTC)
ronpmann
The vegetables in the produce bin are freezing. I've closed the temp control slide between the freezer and frig. The Freezer and Refrigerator seem to be working fine.
woodchuckie
#2 Posted : Wednesday, April 15, 2009 7:38:18 AM(UTC)
woodchuckie
If you close the damper(at the top of fridge), that will prevent cold air from entering the rest of the fridge. You have a separate control at the crisper's you can close and open to adjust the temp there.(is that what you closed)?
There is also a return vent down there. Make sure it's open.
ronpmann
#3 Posted : Wednesday, April 15, 2009 8:20:51 AM(UTC)
ronpmann
Thank you...The crisper was closed. I closed a slide control (labeled Cold or Cooler) that is at the bottom of the refrig and connects to the freezer thru a small opening.....
