Qapla
#1 Posted : Monday, December 31, 2012 4:38:59 AM(UTC)
Qapla
Our unit has started leaving puddles on the floor. Not all the time - but when it does, there is enough water it must be cleaned up, a true puddle.
The ice maker is not connected so it cannot be that.
Qapla
#2 Posted : Monday, January 14, 2013 12:50:08 PM(UTC)
Qapla
Sorry, I did not mean to stump everybody. Still have the problem ... I'll keep looking
heelsfan1961
#3 Posted : Monday, January 14, 2013 6:03:35 PM(UTC)
heelsfan1961
If it is a side by side, check to see if there is a sheet of ice in bottom of freezer. If so, defrost drain is stopped up.
Guest (7)
