wjim
#1 Posted : Thursday, December 6, 2007 6:22:05 AM(UTC)
wjim
washer will run but will not fill with water is this a timer issue? yes the water is turned on:)
#2 Posted : Thursday, December 6, 2007 3:08:19 PM(UTC)
In order to provide most accurate advise I need the complete model number of the washer.
wjim
#3 Posted : Thursday, December 6, 2007 3:26:23 PM(UTC)
wjim
Thank you for replying I am out of town I will get back you this week-end.
wjim
#4 Posted : Saturday, December 8, 2007 6:17:53 PM(UTC)
wjim
The Model number is LAT5910BAW.
Some additional info It runs through all the cycles without stopping but will not fill with water it does spin and agitate. hope this helps
wjim
#5 Posted : Sunday, December 9, 2007 5:24:47 PM(UTC)
The first thing I would check is the water inlet valve (#32 on the cabinet break down diagram).
Check continuity across both coils terminals, replace the water inlet valve if any is open.
If there is nothing wrong, put the water temperature switch on "warm", start the washer and check for 120V to both coils. If there is no power coming, check wires and if this is not the issue, replace the timer (#18 on the control panel break down diagram).
- The part number for the timer AP253024
- The part number for the water inlet valve AP244856
- Here are the break down diagrams for the Maytag washer Model LAT5910BAW
