Door water dispenser works, but no water goes to ice maker. I have replaced water supply valve but still no water to ice maker. Help
The tube that enters the icemaker is probably filled with ice. If so you need to remove the tube and get all of the ice out and this should fix your problem. Icemaker Repair Guide
did you ever find the solution? i have wasted hours trying to troubleshoot with no success.
