rykrishell
#1 Posted : Friday, December 7, 2012 10:01:42 AM(UTC)
rykrishell
Hope you can help me . I have been reading alot on your site for testing front loading washers
This is what i have done so far, I put the washer in test mode and checked for error readings but none came up but a old one for the pump that i replaced . ok i did the inverter test . as soon as i put the washer in test mode i had 120 vac to the blue and red wires ? had power all the time i was using the test mode is this good or bad . then i checked the motor for 6 ohms blue to white blue to red white to red , all had reading of 6ohms . next i checked the sensor resistance value and it was 116.5 ohms not 118 ohms , is that the problem , not sure now . note this washer is a canadian model . i dont know if that would change anything or not, hope you can help me in the right direction. glen:confused:anyone have a ideas what i should do next
#2 Posted : Friday, December 7, 2012 5:37:07 PM(UTC)
The model number you posted does not come up. Verify and repost it please.
rykrishell
#3 Posted : Saturday, December 8, 2012 9:36:01 AM(UTC)
rykrishell
thanks for the reply Gene . this is a washer that is from canada . here is the imformation thats on the side of the washer .
Generral Electric company
model GCVHh6260fww
s/N sh201266t
120v 60 hz 12a
Louisvilie ky
washing machine 25rz
p/no
WMBa0000000050ww
hope you can help
#4 Posted : Tuesday, December 11, 2012 2:44:14 PM(UTC)
If the 120 VAC is present at the inverter AC input harness and motor resistance is correct, replace the inverter.
I'm not able to find the correct part number for the inverter because we do not have access for non American models parts list.
rykrishell
#5 Posted : Tuesday, December 11, 2012 11:57:22 PM(UTC)
rykrishell
thanks Gene i will replace the inverter and will post back , thanks again for your help :D
rykrishell
#6 Posted : Wednesday, December 12, 2012 9:38:55 AM(UTC)
rykrishell
Hi gene the number on the inverter in the machine was a Emerson Model aa23580 made of metal . looks like you cant get that one anymore . i think it was replaced with wh12x10418 . the new one is smaller and made with plastic . i hope thats right ?:confused:
#7 Posted : Wednesday, December 12, 2012 2:22:24 PM(UTC)
Hello,
Very likely this is the correct part number but I'm not able to verify it.
#8 Posted : Wednesday, December 12, 2012 2:32:34 PM(UTC)
Originally Posted by: peter50 Go to Quoted Post
Gene you really did the awesome job. Its valuable...
Keep it up...
Thank you for your good words. Happy Holidays!
rykrishell
#9 Posted : Monday, December 17, 2012 7:02:29 AM(UTC)
rykrishell
Hello,
Well Gene i put in the new inverter and the washer is up and running great . I was using it all weekend with no trouble at all . I really like to thank you for all the help that you gave .I had know idea what to do before i found this form and started reading and asking questions .Merry Christmas to all :D
#10 Posted : Monday, December 17, 2012 10:12:59 AM(UTC)
You are welcome. I'm glad it's up and running.
Merry Christmas to you and your loved ones!
