Tippy73
#1 Posted : Friday, December 14, 2012 3:07:36 PM(UTC)
Tippy73
Need help! Our dryer is spinning when turned on, but no heat. There is no electric boards or panel on this unit.
After reading online, we (my husband) changed out the Heating Assembly Unit (large round unit with coil). Put the dryer back together and still no heat.
Read that turning the breaker on/off could possibly solve the problem. That did not work. Still no heat.
FRUSTRATED and he wants to just get a new dryer. Ummm...no.
Not sure how to check if the fuse is blown. Looks perfetly normal, not black/brown/discolored.
Everything else is functioning.
ANY help would be greatly appreciated. THANK YOU in advance!
Jen
Simon / APP Team
#2 Posted : Friday, December 14, 2012 3:57:08 PM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
First check if there is 240VAC at the dryer connector block.
If it is next check the control and hi-limit thermostats.
Control thermostat Part number: 131298300
Located on the blower housing.
Hi-limit Part number: 3204267
Located on the top right of the heater housing.
You need to have a multimeter to run the continuity tests or otherwise you will continue buying unnecessary parts.
Here are the breakdown diagrams and Cabinet / Drum parts for Frigidaire GLER341AS2 - AppliancePartsPros.com
Post the results.
Simon.
Tippy73
#3 Posted : Saturday, December 15, 2012 10:32:55 AM(UTC)
Tippy73
Thanks for your reply! My husband took those 2 parts to the appliance store. They tested them and said they were functioning properly. So he came home with a voltage tester and despite turning on/off the breaker, the breaker was bad.
So, we have a new/spare heating element and breaker - most important - proper functioning dryer.
Thank you for taking time to help us out!!
Simon / APP Team
#4 Posted : Monday, December 17, 2012 9:01:24 AM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
Guest (4)
