Omar Leal
#1 Posted : Monday, April 13, 2009 4:32:56 PM(UTC)
Omar Leal
Freezer is cooling perfect... Refigerator is not cooling down... What could be the problem, so I can take a look at it? Please Advise...
woodchuckie
#2 Posted : Monday, April 13, 2009 7:51:30 PM(UTC)
woodchuckie
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's open.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check, defrost heater, defrost thermostat Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
If they check out ok the defrost problem is the motherboard. Part 703
http://www.appliancepartspros.com/sect/u/m/a/uma52utbzq.gif
