Mwells32
#1 Posted : Tuesday, December 11, 2012 7:02:22 PM(UTC)
Mwells32
It all started when my daughter used he microwave as a timer, and ran it empty. I checked all the fuses with a meter and found one that was open. It is on the back wall behind the control pad. I have looked at the exploded diagram and for the life of me cannot see what part it is. I ordered a part here, then tried my local shop. Both look like the same part, but have different part numbers. When I hook the new parts up and plug it back in, the exhaust fan stays on. You can turn it up to high, then back to low, but not off. The microwave works. I took the wires off and jumped them together and everything works just fine. I'm starting to get pretty frustrated.
Simon / APP Team
#2 Posted : Wednesday, December 12, 2012 11:27:00 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
I think you mixed the thermostats and put in a normally closed one instead of the normally open one.
What is the part # and also, please provide the complete model number of the unit.
Simon.
exhaust fan won't turn off after no heat repair (Microwave Repair)
by jcantergiani 11/15/2012 5:22:29 AM(UTC)
Whirlpool Microwave Over-the-Range Vent Fan Won't Turn Off (Microwave Repair)
by svsu9033 12/29/2011 8:16:19 AM(UTC)
Kenmore cooktop cooling fan won't turn off after use (Oven Repair (including Ranges and Cooktops))
by frustratedbill 8/19/2011 10:32:00 AM(UTC)
Microwave vent fan won't turn off (Microwave Repair)
by Ginnyndoug 11/16/2010 5:29:27 AM(UTC)
wolf Model DF304 Stove fan won't turn off (Oven Repair (including Ranges and Cooktops))
by junebugtraveler 3/27/2010 7:17:21 PM(UTC)
